Results 1 to 1 of 1
Thread: Top red brake light on - spongey brake pedal Mk 1
    Oct 2006
    Albany Creek Brisbane
    Smile Top red brake light on - spongey brake pedal Mk 1
    Hi all
    During the week I noticed that my brake pedal felt a bit spongey, when applying the brakes the initial stroke nearly went tothe floor which was a bit scary! the second stroke was better. After a few minutes the brake pedal was spongey again...
    Today the top red brake light (the one with the brake linings) came on and I heard a grinding noise from the front LHS wheel, it is worse when turning. I had a similar noise about a month ago which went away after a week or so.
    What could cause this, pads, booster? The brake fluid seems to be at the correct level in the reservoir etc
    I bought some jack stands to day to investigate further - any ideas please before I start to do the work
    Thanks
