Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Todays Suspension upgrade courtesy of E-Bay and Fiddly bits.
  1. #21
    A good setting for a street driven mk1 is standard toe setting & around 0.8-1 degree of negative camber.
    Good turn in & not harse on the tyre's. I've set all of my mk1's like this & have never had any problem's.
    I've got to say that, I don't think the back will settle as much as you think. From all of my spring's & spring's I've fitted to all sort's of cars it's normally about 15mm.
    Excellent write up too!!
  2. #22
    Boronia VIC
    Yeah, I'm not sure about the ride height. My other golf has the same shocks and springs and it's sitting level.
    The springs are King springs - 30mm lowered but these are from a new batch using a different steel (according to the packaging.)
    The front seems to be a bit lower than the other golf too.
    I'll just wait and see how it goes for now.
    What is the standard toe in for a golf BTW?
    Pete
  3. #23
    Jun 2007
    Eastern Suburbs Melbourne
    nice little write up pete. This will come in handy the next time I put new suspension in! haha.
    I will be insterested to see how you go fitting the new booster and rear brakes.
    i like volkswagens
  4. #24
    Gosford Central Coast NSW
    standard toe setting is a teeny bit of toe out. just barely a little.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  5. #25
    Boronia VIC
    Figured out the rear ride height. I'd reused the lower spring seats from the old shocks and installed the the same way they were installed on the original shocks - Upside down!
    I'm not sure why they were upside down on the originals, the front always rode very high, perhaps the back had sagged and this was a cheap way to raise the back to match?
    I realised when I discovered new spring seats in the bottom of the boxes that the shocks came in. A silly mistake, but easily fixed.
    Here's a shot of the difference. Correct on the left and upside down on the right.
    And a shot of the car with the shocks fixed up.
  6. #26
    May 2006
    Maryborough Vic
    Talking
    looks much bettera
    must drive like a new car
    ride hight looks good too
