Results 1 to 10 of 13
Thread: Timing belt refitting
    reborn Guest
    Today my loyal friends and I replaced the water pump on the Mk1 (1.6tr). To do this we had to remove the timing belt. We marked them off however when we refitted there was no fire...
    Can anyone advise me how to get the timing right? (timing points?)
    This stuff should be in the manual right?
    Its not leaking any water!
    Camden, Sydney
    Line up the notch on the bottom end pulley with the mark on the belt cover. Check its right with a screwdriver down no 1 plug hole.
    Line up the mark on the top pulley on the cam.
    Often the mark is on the inside of the wheel and lines up with the top of the head.
    At least its a 1.6 and non interference
    Apr 2006
    Hobart,Tas
    0 on the flywheel is TDC.
    Remove the dizzie cap and turn the aux shaft till the rotor is lined up with no.1 notch in the body of the dizzie.
    The notch on the inside of the cam sprocketshould be set to line up with the top of the rocker to head surface, where it sits on the head. That is, to line up with the actual rocker cover, not the head surface.
    The adjuster should always be adjusted in a clockwise direction.
    By the way, the cam belt doesn't have to be removed to do a Mk1 timing belt.
    Good luck with it, and let us know how you get on with it.
    Andrew
    Aug 2005
    Quote Originally Posted by gtimk5 View Post
    hahaha...Iknow what you meant to say....., I was thinking the 'same' thing as you do not have to remove the timing belt to replace the water pump, you loosen the belt at the alternator.
    reborn Guest
    Quote Originally Posted by Dan View Post
    Loosen off the alternater... Not to take off the timing belt?!? To drop the waterpump, because it is 'inset' it appeared we had to take off the lower gear. If it can be done how?
    Anyway we have followed the steps and the timing should be right now however it will still not fire. We suspect that the severe backfiring has had some effect on the carby which is blowing a heap of fuel out of the breather hole now. A carbie spitting fuel like that is surely stuffed?!?
    We will put the 32/36 on it with the new manifold and see if we have any joy.
    If you just replace the pump and not the housing as well then the timing belt gets in the way.
    Doing this is false economy as the additional time taken far outweighs the cost of the full pump.
    reborn Guest
    indeed it is! yes, we did the housing as well. Could not for ths life of see it coming off without the extra work. thanks Gavin
    They do for sure mate. 4 big bolts from the front and one that goes through the tinwork behind the cambelt.
    It's been a year since I did one but I am 99% sure the cambelt needn't be touched.
    You should at least be pleased it wasn't the pump in a G60, as they really are a swine to do.
    The charger has to come out as it's bracket is held on by the same bolts as the pump.
    Just seen it's a diesel, maybe that makes a difference?
    reborn Guest
    It is a red coat GLD. The first owner put a 1.6 petrol in it when the diesel blew up in remote North west WA many years ago. It was the quickest replacement they could find...
    Just hope this new webber gets me mobile again - it always happens at the worst times!
    Apr 2006
    Hobart,Tas
    It is a very simple job to remove the 4 8m/m bolts and timing cover 6 m/m bolt.
    You need to step back 1st and think, why did it backfire after you reset the cam timing? The needle valve must be sticking if fuel is coming out of the discharge nozzle. Carbies dont just "stuff up" like that.
    Before you go changing manifolds and carbies, find out why it doesnt all of a sudden go.
    Good luck, Andrew
