Results 1 to 10 of 23
Thread: Timing Belt help
    Sep 2009
    Chillaxing in Tas
    Timing Belt help
    First of all, read the Haynes Manual, and browsed for hour or so on here...
    Problem is, i had to replace a cracked camshaft wheel on my spare 1.8L.
    now ive aligned the camwheel line to the rocker cover as said in manual. have aligned the v notch on crank to the dot on the itermediate shaft wheel.
    Now this is the tricky bit, when i go to tension the belt the crank and the other wheel move out of alignment.
    Any tips on how to stop this? if i manage to get it one tooth out, what will happen? im guessing all this has to be spot on?
    Ahwell, back off to read some more,
    <space for rent>
    Jun 2007
    Eastern Suburbs Melbourne
    the tensioner 'adjusts' the belt on the back side of the engine. go out and have a look and you'll see that on the front side of the engine, the timing belt goes stright from the crank pulley to the cam pulley. make sure they're lined up (in terms of the 'tooths' and then tighten. That should keep the notch's all lined up.
    i like volkswagens
    Camden, Sydney
    It doesnt matter if the intermediate shaft is not lined up, as you can correct it by moving the dissy.
    The top and the bottom should be set with a taught belt between bottom and top and the tensioner adjusted on the slack side.
    Sep 2009
    Chillaxing in Tas
    ahhk, will give it a shot.
    so, put belt on ant make sure its not a tooth out, make sure its on TDC and adjust dizzy in a manner to make it facing #1 cylinder
    Too easy..
    <space for rent>
    Sep 2009
    Chillaxing in Tas
    Ok im stumped.
    If i line up the crank pulley with the other pully, then line up the cam pulley. when i go to put belt on, the came pully is out and the belt dont go on. if i turn it slightly it will but then the cam line is not lined up.
    how do you guys do it? i know i dont need to line up the other pulley cause you can move dizzy to correct the TDC poistion thingy.
    How do you line up the crank? i got the clutch and flywheel back on. far as i can i got it on right, timing marks should be same side as the notch on crank pulley yes?other wise it would be out by like 90 degrees
    Anyway, help be good.
    <space for rent>
    Sep 2009
    Chillaxing in Tas
    Ok,
    spent an hour outside on engine today, and i dunno if i can get it right.
    First of all do i line the camshaft wheel level with the head? or the tappet cover?
    If its tappet cover, ignore rest of post. if its the Head. continue
    Ive got camshaft lined up, then got crank, then got other shaft lined up. got belt on and hey it worked. rotated crank twice and now marks are slightly off.
    Also, included pic of the flywheel as it sits when the crank pulley is lined up to the other shaft. How do i check to make sure its fine from the flywheel end? Manual is making no sence to me :S
    Edit, that flywheel and clutch is off a different 1.8L. will this affect anything? it looks same as one that came off this motor. (besides one on it now being a much better clutch)
    <space for rent>
