Yeah grab a meter and make sure you've got power dude.![]()
my thermo fans not working and im at a loss as to why, because it worked just fine before i did the engine swap.
any ideas? i've checked out 2 fans, bipassed the radiator switch to hard wire it and both dont work, maybe a fuse?
cheers
They are the most simply wired thing on the mk1s.
Power to fan and negative switching through the thermo switch!!
Andrew![]()
If there's no power check your fuses, mine was wired to the one on the far right.
Pete
cheers ill check it out, hopefully its just a fuse
if its not a fuse, check your plugs in the back the fuses
that was the cause of mine not working
cheers chaps, will do tommorow in the light![]()
