The radiator cap will cause them to run hot very quickly and will cause coolant loss. Less than $20, its not a bad place to start.
The temp gauges on different Mk1s run in different ranges. The only way to see how hot it is getting is to stick a temperature gauge in the radiator when the car is idling at standstill.
Good luck, Andrew
