Results 1 to 10 of 17
Thread: teledials
    Jan 2012
    Hamilton, QLD
    teledials
    So got hold of a set of proper porsche teledials a while ago and they've been sat in my storage since then.
    When I bought them I was proper into the idea of putting them on the golf, after they were refurbed of course.
    But when I saw them in the flesh I was a bit gutted because they're not as cool as I thought?! I think with all the hassle of getting 5x130 to 4x100 adapters and getting new tyres put on them and all that palava, they don't really seem worth it.
    Anyway, if anyone knows of somewhere in Aus that I can get hold of those adapters and them not cost the earth, that would be sweet.
    Also if anyone knows anywhere to get them refurbed in Brisbane that would be sick. I tried depulu but they wanted like over a grand. I'd do them myself again rather than spend that money.
    If not then they're going back on fleabay.
    # 76 Mk1 16v In Progress # 2011 6R Polo GTI *Sorely Missed*
    Oct 2010
    Wagga , NSW
    Im sure adaptec will be able to do them, all their prices are between $350-$400 landed. what size are the wheels anyway?
    Jun 2007
    Eastern Suburbs Melbourne
    H&R do off the shelf adapters for porsche to mk 1 fitments. adaptec would also do them
    i like volkswagens
    Jan 2012
    Hamilton, QLD
    That's so expensive bloody hell! Gutted. I think I saw some online on eBay from back home for like $200 ish landed. I'll try to find the link. I dunno what they're like though might be better to avoid cheaper ones if they're keeping my wheels on right.
    I'm pretty sure the wheels are 15x6 and 15x5.5 but that could be completely wrong. I'll have to check when I get back to Brisbane.
    Has anyone else on this forum moved to 5 studs?
    ---------- Post added at 09:05 AM ---------- Previous post was at 09:02 AM ----------
    eBay Australia: Buy new & used fashion, electronics & home d
    Found it!
    What do you reckon, are these legit, will they even work?
    Quote Originally Posted by BonsaiTiger View Post
    Found it!
    They may work, they are illegal.
    Jul 2005
    Newcastle, NSW
    Quote Originally Posted by RedMk2Gti View Post
    Any spacer/adaptor that is not OEM is illegal, but that was not the question
    Jan 2012
    Hamilton, QLD
    Haha I like that. Chances of getting collared on the street would be low with something like that surely? Still don't know if I like them enough to go through the messing about though. Fancy some like this..
    To be honest there's about fifty different wheels / looks I want for my mk1 and I cant decide at all.
    Jan 2012
    Hamilton, QLD
    So I did a bit of research and these appear to be a really rare set of "flat-faced" 928 or 924 porker rims from 1978/1979 (2 year manufacture period before they went to the curved face of other teledials). Sweet!
    I looked into them and these 15 x 7 ones are apparently et53! which means if I get a set of 20mm adapters they'll sit at et33? How would that look roughly? Any ideas? I think I read that et 25 is pretty good for mk1s? Will the look daft like the dont fill the arches, or maybe if I go low enough they'll look sweet all tucked up.
    I'll get some pics up tomorrow when I get a chance.
    Interesting, maybe I'll hang on to them after all!
    Jun 2007
    ET33 is about the highest offset you'll want to go. higher offsets will tend to fould on the coilovers that you'll be running. also tyre size and camber are very important.
    et25 is generally considered 'flush' for the front arches, on a 7" wheel.
    i like volkswagens
    Jan 2012
    Hamilton, QLD
    Here are some pictures of the wheels. If they are et53 and I add a 20 mm spacer then they will be et33 right? I that how it works? Aren't there positive and negative offsets too? Whats the difference?
    As you can see the hub mounts are really close to the front of the wheel. This means it is less likely to poke out of the rim and more likely to rub on the coilovers or whatever suspension is in there. Does that sound right? How do I make these effing things fit?
    Also, what do you guys think of the flat face version of these things? I thought I had the curved ones like the ones below but appaently not, I like these way more than I thought!
    Cheers for the help like
