Results 1 to 5 of 5
Thread: Tail lights
    Sunny Coast - The QLD
    Tail lights
    My tail lights are rubbish. I have pulled everything out and given it all a good clean and made sure that it all is good to go and replaced all the lamps/bulbs and still I have problems with it. The right indicator has a mind of its own and I am constantly having people tell me "Hey mate your parkers dont work", or "Your left brake light is broke". One a week I drag my lady out to check that everything works and sure enough something is not right every time, but jiggle the bulb and it comes good.
    What has everyone else done? Have people replaced the whole lot? If so from where? I would love to get a whole LED setup but havent really done enough research to even get that far.
    Any help would be great.
    MK1 floG soon to have 16v 2L with cable change gbox - need a 16v turbo manifold
    "Fit the gearbox ya bum." Loon - best post ever!
    Jan 2006
    Lowood Qld
    i'll send u a neat clean repl set for $75 incl bulbs he he
    no cracks
    came off a 80 diesel
    german - english translations esp vw documents!!
    Dismantling 95 Seat Cord'a and 73 campers and 74 dc van !!! Some Mk1 and t2 ant3 gear in my stash,,,
    Jul 2009
    Ringwood,Victoria
    Follow the earth or negative wires to where they connect to the body and make sure the female connector is tight on it's male counterpart.
    If it's slack,squeeze the female connector with pliers to make it a tight fit again.
    We all get a bit slack with age.
    "That's what she said"
    Jun 2007
    Eastern Suburbs Melbourne
    just tap the light to make it come back on.
    also works for headlights.
    if not change occours. wait till tomorrow.
    i like volkswagens
    Dec 2007
    Somewhere in Melbourne, Victoria
    tail light assembly in old Mk1's are notorious for:
    A. rubber seals perishing in the Australian heat & sun
    B. metal brackets start to corrode because of A.
    C. rear hatch seal leaking and allowing water to cascade into cargo area and ultimately the tail light assemblies.
    If you can replace hatch seal then get to cleaning up the lights as follows:
    If the lenses are OK (not going opaque or losing their colour):
    1. rip them out, clean them up real well and try to replace rubber seal with a new rubber strip (Clark Rubber might be the go) and add some silicone based lubricant to the rubber before you reassemble.
    2. for the wiring, clean up the metal holder and connectors, replace an dodgy connectors with new ones (crimp set will do) and reassemble.
    lots of fun for all.
    1991 Golf GTI Manual - Tornado Red (Little Red Wagen)
    1998 Golf Cabriolet Manual - Black Magic Pearl (aka Rommel's Panzer) Deceased/written off
    1993 Golf Cabriolet Manual - Alpine White (aka Hitler Youth Wagen) Deceased/written off
    1976 Golf LS Manual - Bronco Brown (aka Roadrunner) Deceased/worn out
