you can also just put 90mm flanges on the 5-speed box.
yes, but not straight on. the driveshafts need to be 'cleared' to fir the bigger CV.s i'm unsure on exact specs, cause I've never done it, but i've seen it done with an angle grinder , the proper way would be to get a machine shop to take off the reg distance, or find 90mm driveshaft flanges (bit on the gbox) i believe they're rareish and hard to find.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
I had no problem bolting my 90mm CVs to a diesel 5spd..
EDIT: Now that I think about it the box was from a Mk2 Diesel.. mid 80's I think
76' 2dr Kjet
Hmmm confusing stuff
Think the 5 speed i got is a Mk2 item? not tooo sure, might have to ask the previous owner..
<space for rent>
There are 3 kinds of flanges
90mm 4 speed ones, that only fit 4 speeds.
90mm 5 speed ones which have a step in for the oil seal and stick out further than the 4 speed ones.
(These are found on MK1 GTI gearboxes and Early Mk2, including diesels)
100mm ones as found on later Mk2 and Mk3s.
Actually there are also 90mm ones on Golf 4 1.6 boxes, but they are different as they are held in with a bolt, not a circlip.
Hope that clears it up, I know my gearboxes
yea it does, thanks loon!
btw, do you happen to have any 90mm 5 speed flanges lying around?
