That ****s just starting to get serious!
ahhh i've been wanting that front brake set up forever! had my eye on that wilwood kit! awsome work al, so so jealous! ahah
78 2-door 1.8 KR 16v - twin dellorto's
Suitably over kill, in spirit with the project!
Workmanship is looking excellent Al,
Just a little heads up on using a corrado bearing housing, it will allow you to take that extremely long steering joint bolt out of the picture, ( huge bending load being so long ) and bring the bolt length back to manageable loading limits. Also has a larger wheel bearing ( last longer with the low offset wheel specs)
VW Performance - Autotech Sport Tuning: Corrado Steering Knuckle, Spindle right
moar pics![]()
Lots of MK 1 Scirocco's...
Cheers,
Grant...
Nice find wish I had of known about these a while back.
I not worried about the tie rod extension though, the primary material is 4140 chromoly and is 16mm thick, they are built for speedway builds and are IMCA approved. I have also added an external sleeve so the strength is improved more still.
They look a lot like the ones I'm using except mine are from a MK2 16v. Bigger wheel bearing and 19mm Ball joint, down swept steering arm. Need to be modified to MK1 strut bolt hole spacing.
They've also got the MK3 caliper bolt spacing which opens up the brake upgrade options.
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
I feel like I'm looking at something dirty. Very dirty. I like.
