Page 101 of 134 FirstFirst ... 519199100101102103111 ... LastLast
Results 1,001 to 1,010 of 1334
Thread: the swallow tail project has begun.......
  1. #1001
    Jul 2005
    Newcastle, NSW
    That ****s just starting to get serious!
  2. #1002
    sydney
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
  3. #1003
    Mar 2009
    ahhh i've been wanting that front brake set up forever! had my eye on that wilwood kit! awsome work al, so so jealous! ahah
    78 2-door 1.8 KR 16v - twin dellorto's
  4. #1004
    sydney
    Really is an awesome set up , the calipers are so light it's ridiculous. And the pad change is so simple , can't wait to stomp on them.
  5. #1005
    Jul 2005
    Newcastle, NSW
    Suitably over kill, in spirit with the project!
  6. #1006
    Perth. WA
    Quote Originally Posted by alex g View Post
    Workmanship is looking excellent Al,
    Just a little heads up on using a corrado bearing housing, it will allow you to take that extremely long steering joint bolt out of the picture, ( huge bending load being so long ) and bring the bolt length back to manageable loading limits. Also has a larger wheel bearing ( last longer with the low offset wheel specs)
    VW Performance - Autotech Sport Tuning: Corrado Steering Knuckle, Spindle right
    moar pics
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  7. #1007
    sydney
    Nice find wish I had of known about these a while back.
    I not worried about the tie rod extension though, the primary material is 4140 chromoly and is 16mm thick, they are built for speedway builds and are IMCA approved. I have also added an external sleeve so the strength is improved more still.
  8. #1008
    Boronia VIC
    Quote Originally Posted by roccodingo View Post
    They look a lot like the ones I'm using except mine are from a MK2 16v. Bigger wheel bearing and 19mm Ball joint, down swept steering arm. Need to be modified to MK1 strut bolt hole spacing.
    They've also got the MK3 caliper bolt spacing which opens up the brake upgrade options.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  9. #1009
    sydney
  10. #1010
    Jun 2007
    Eastern Suburbs Melbourne
    I feel like I'm looking at something dirty. Very dirty. I like.
    i like volkswagens
Similar Threads
  1. Audi 90 Quattro 20V Project
    By type89 in forum The Audi Quarter
    Last Post: 28-09-2006, 10:36 PM
