Page 57 of 134 FirstFirst ... 747555657585967107 ... LastLast
Results 561 to 570 of 1334
Thread: the swallow tail project has begun.......
  1. #561
    Jun 2007
    Eastern Suburbs Melbourne
    Quote Originally Posted by roccodingo View Post
    ... it will only make the lower arm angle down more.
    I would have thought that would have been the idea, in combination with a tie rod flip kit to help eliminate bump steer on severly lowered golfs.
    ref:
    http://www.vwwatercooled.org.au/newf...e+rod+flip+kit
    i like volkswagens
  2. #562
    sydney
    the way i see it is it is a direct reflection of the arch of the lower arm, not the position of the pivot.
    bump steer is created by the arm travelling to far up and pulling the geometry off , by correcting the arch to be more centralised and making the movement more up and down as apposed to up and in, will decrease the pull on the lower hub attachment
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
  3. #563
    Oct 2006
    sydney
    nice mate this car what sort of time line till its ready im itching
  4. #564
    Perth. WA
    ref:
    The idea is to keep the A arm parallel with the ground, with the tie rod following suit ( parallel) note water boys top pic, without the tie rod flip the two arms would not be parallel, thats what causes the bump steer effect.
    Note also that the ball joint extender lowers the a arm outer pivot, that is what changes the roll centre ( see next post )
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  5. #565
    Perth. WA
    Quote Originally Posted by alex g View Post
    Bump steer is created when the suspension arm and tie rod deviate to much from a parallel situation.
    Roll Centers
    Every vehicle has a front roll center and rear roll center. They are independant from each other and are determined by suspension geometry.
    The front roll center of a car with MacPherson strut suspension can be found as follows:
    * Draw a line at an angle of 90 degrees from the top of the front strut
    * Draw a second line through the lower control arm. The point where these lines intersect is the instantaneous center
    * Draw a third line from the instantaneous center to the center of the tire contact patch. The point where this third line crosses the car's centerline at the roll center.
    Note in the diagram below how lowering the car by installing shorter springs changes the angle of the control arm and moves the roll center closer to (or even below) the ground.
    And more...
    "During high laterally loading (going around corners) a car leans not over the
    contact patches at ground level, but around something called the roll center, a
    point in space which is determined by how all the various suspension parts move
    relative to the chassis. A car with double wishbone suspension can be designed
    with the roll center at the CG, below it, or even above it (the car would lean into the turns).
    The tendancy of a car to lean is determined not by how far the
    CG is above the ground, but how far the CG is from the roll center.
    Here's the problem. When you lower a car with MacPherson struts (our cars)
    the roll center lowers farther/faster than the CG. So if at the stock height the
    roll center is 4 inches below the CG, when you lower the car 2" the CG
    drops 2" but the roll center drops say 6". The actual tendancy of the car
    to lean during cornering then increases.
    The reason MacPherson strut equipped cars have this problem is
    because the angle of the lower A-arm relative to the chassis changes
    as you lower the car. Lower too far and the arm tilts
    the wrong way, lower on the chassis side and higher on the strut side
    and the rolling of the car has a greater mechanical advantage on the
    strut causing it to compress the spring easier as the weight
    shifts to the outside. That change in geometry is what changes the
    roll center.
    It has other negative side effects too. At the stock height, the
    lower A-arm is higher on the chassis side, and lower at the hub.
    When the suspension compresses under cornering the arm moves
    both up toward parallel with the ground, and because it pivots
    on the car side, the outside end moves out a little as well. That changes
    the angle of the strut itself pushing the bottom out, causing a bit of added
    negative camber relative to the static position. That is a good thing,
    especially for our front heavy cars."
    "You want the added negative camber to give you better laterally grip
    as the car leans and as the tire sidewalls roll over a bit. (Race tires
    can compensate for decreased negative camber by having stiffer/higher outer
    sidewalls.. . )
    As you lower the car moderately the A-arm starts out parallel to the ground
    and now with suspension compression during cornering, the arm swings
    through the part of the arc where there is no change in camber. That'd
    be fine if you could totally eliminate body lean while still having usable
    suspension travel (you can do this with a double A-arm suspension but not
    with a MacPherson strut).
    If you continue to lower, you experience the problems above, but
    in addition now the A-arm is above parallel so you have to dial in
    lots of static negative camber, and ANY suspension compression causes
    the arm to swing up and back inward tilting the bottom of the strut inward
    as well causing a positive camber change. A positive camber change
    during hard cornering is *NEVER* desirable. The tire is leaning
    the wrong way. So add it all up; the roll center lowers faster
    than the CG, so the car actually wants to lean more, you have less
    suspension travel so that lean causes you to come down on the bump
    stops causing instantaneous weight transfer, and you push into positive
    camber, all of which decreases your lateral grip, sometimes suddenly.
    Check out the rear end of a swing axle beetle
    There is actually a way to fix a lot of these problems, and it's
    called a drop spindle. Basically you drop the car with springs, decreasing
    the distance from strut top to wheel, but then the hub has a lower A-arm
    attachment point that sticks down below normal. That allows
    the actual geometry of the strut and lower A-arm to remain the same
    but the car to sit lower. Another way to picture it is if you leave
    the stock looking strut in place, and simply moved the hub
    that the wheel attaches to upwards. That lowers the car keeping
    everything else the same.
    The bad news.. They don't make drop spindles for our cars. Period."
    This is where your spindle extension comes into play, it brings the roll centre back to where it should be and lowers the car, ( thats what you want ) but the pivot needs to stay as close to the a arm as possible.
    Im not critisizing what you have done at all, just want you to gain the benefit of what you have done.
    Cheers,
    Grant...
  6. #566
    Sep 2006
    Parkinson / Brisbane
    How can us mortals compete with this?! honestly, this build is the greatest dub build of all Australian time
  7. #567
    sydney
    cheers
    i cant see how the pivot being 30mm different would make any difference, as it says above the main effect you are trying to combat is the arch of the lower arm,ie how far it pull and pushes out from the car, by dropping the a arm(as mentioned)it makes the movement more up and down less in and up, i cant see that the pivot sould play such a big role
    the tie rods are being flipped too
    here are some similar examples
    and in a upside down fashion (the pricable is the same)
  8. #568
    Jul 2005
    Newcastle, NSW
    Test it, like it - keep it. Don't like it - change.
    I need more skills in things like suspension geometry.
    Could you find some time this week for me to build up some rear axle spacers?
  9. #569
    Perth. WA
    Best thing you can do is find a good technical suspension book and understand the principles, Go visit the racetrack and seek knowledgeable people there.
    The spacer pic you have is showing the ball joint being spaced further away from the lower arm pivot ( look where the bolt holes are) and for a top ball joint on a different suspension arrangement, ( probably to extend the track 15 mm each side if there used top and bottom ) again thats a different ball game all together with reference to the Macpherson strut arrangements that the Mk1 use.
    Even changing the position of the pivot points by several millimetres has an effect.
    Good to see the tie rod is flipped, but by having the ball joint on top of the a arm spacer your in effect probably making the bump steer worse. Do some reading, their is loads of info out there so you can make a test jig and physically determine the best set up.
    To lower the car your effectively moving the wheel rotational centre UP the suspension tube, you do this by adding the spacer to the top of the ball joint, then you need to accomodate the top of the strut by using extended towers or shorter shock & spring combinations. Once this is done to keep the steering geometry in the same relationship as it was originally ( it has a particular geometry for a reason , handling ) you need to lower the steering tie rod position ( which you have already done) the 30 mm which "should" coincide with how much you extend the ball joint down.
    When it comes to the suspension operating principles, its not how the part appears, but where the pivot points are, the lower a arm could have 4 bends in it but if the pivots are in the same spot it will react and move the same as original. Look at what the pivot points are doing not how angled the a arm is.
    You want the a arm at its most horizontal position when the car is at your preffered ride height ( maximum distance from the inboard pivot ) then going into wheel movement will have the least amount of disruption to the steering.
    Its good to have a car go quick and be fast, but you also want to maximise the handling abilities ( thats the bottom line ) and keep it safe.( paramount )
    I want to see you get this right Alex, the amount of work you got in this means get the best result bud
    Cheers,
    Grant...
  10. #570
    Jun 2007
    Quote Originally Posted by KI11Z View Post
    I reckon!
    I'm going to have to re-read this another couple of times to understand it, but I'm willing to learn!
    i like volkswagens
Similar Threads
  1. Audi 90 Quattro 20V Project
    By type89 in forum The Audi Quarter
    Last Post: 28-09-2006, 10:36 PM
