Page 50 of 134 FirstFirst ... 40484950515260100 ... LastLast
Results 491 to 500 of 1334
Thread: the swallow tail project has begun.......
  1. #491
    sydney
    i thought when you said sligthly larger it could have been half a mm a side , they also have clearance cuts for the valves
    thanks for the help
    its all a little new this internals stuff
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
  2. #492
    sydney
  3. #493
    sydney
  4. #494
    Jun 2006
    Orange NSW
    Quote Originally Posted by alex g View Post
    thanks for the help
    All good dude. By slightly larger i meant like .15mm or so. A bit hard to measure if you're not that great with calipers.
    Everyone has to start somewhere, and you've got everything else down pat for sure, so start reading up on it.
    Oh, PS, your block...
  5. #495
    sydney
    lightened and trued the intermediate shaft
  6. #496
    Oct 2006
    sydney
    awesome work alex as always. the heart of the beast is gleaming
  7. #497
    Jun 2006
    Orange NSW
    Hmmm. I seem to recall one pretty much the same somewhere that i've seen...
    Very nice. Just the way i'd do it.
  8. #498
    sydney
    yer i actually saw jarred aka xkromx do his and then you but there is something they say about great minds
  9. #499
    Jun 2006
    Orange NSW
    Haha very true.
  10. #500
    Jun 2006
    Orange NSW
    [QUOTE=Preen59;320927]81mm is standard bore. So 81 may be the piston size. The "bore size" is actually the piston size. The bore will be slightly larger (bore clearance etc, you know). QUOTE]
    To get technical on piston sizes the bores are machined exactly to a standard size of say 81.00mm in the standard motor and as mentioned increase in 0.50mm increments. 81.50mm, 82.00mm etc
    The clearance is machined into the pistons and varies from standard cast pistons to aftermarket forged pistons. The mean diameter clearance from factory on cast pistons is 0.05mm less than the bore diameter,
    so for a 81.00mm bore the pistons are 80.95mm diameter. Forged pistons such as wiseco with teflon coated skirts have a recomended clearance
    0.0625mm and JE has 0.075mm.
    Pistons are measured with micrometers 10mm up the skirt and at 90 degrees to the gudgeon pin.
    After boring and honing to many blocks to mention id recommend wiseco in an NA build up such as yours if you do bore it out. They are the quietest and lightest pistons on the forged piston market.
Similar Threads
  1. Audi 90 Quattro 20V Project
    By type89 in forum The Audi Quarter
    Last Post: 28-09-2006, 10:36 PM
