Results 1 to 10 of 18
Thread: noisy driving.
    noisy driving.
    my little 76 two door is a blast to drive but its soooo bloody noisy and it jumps (like a bunny hop) in low revs (1500rpm) in second when it shouldnt. im thinking its the CV joints. i am going to replace the CV joints and all wheel bearings in it to see if that helps. also in both the 77 and the 76 the exaust rattles around a fair bit. any suggestions?
    imported_brackie Guest
    Re: noisy driving.
    Quote Originally Posted by GoLfMan
    my little 76 two door is a blast to drive but its soooo bloody noisy and it in low revs (1500rpm) in second when it shouldnt. im thinking its the CV joints. i am going to replace the CV joints and all wheel bearings in it to see if that helps. also in both the 77 and the 76 the exaust rattles around a fair bit. any suggestions?
    Jumping.....jumps (like a bunny hop), maybe that's why they're called a Rabbit in the US.... sounds like engine/transmission mounts. The high torque in low gears really gives the front an back mounts some stick. The mount near the gear linkage usually goes first as it gets oil on it and is close to the downpipe.
    Probably not CVs. They get very little wear in the straight ahead position. Give her a spin left and right on full lock. Knackered CVs will click if they need replacing.
    Worn wheel bearings are probably the culprit. Rear ones are easy to check. Jack her up and give the wheels a spin. You'll feel roughness and hear noise if they are stuffed. Front ones are a different matter. It's a lot harder to spin the wheels when raised and because of the involvement of the drive shafts noise and roughness are more difficult to detect. In the past I have jacked a wheel, chocked the car and let the wheel spin in gear to find a worn bearing. Not recommending this...Just saying that I have done it! You can feel play in the front bearings by raising the car, grabbing the wheel and moving it from the top and bottom. The bearings have 2 races in them and you'll feel wear straight away. If you have to replace the front ones you'll need a press to do it properly.
    thanks mate. thats a load off my mind with the CV joints and a load off my wallet! i it might be the wheel bearings so ill give them a shot next time i have i work with it.
    Camden, Sydney
    4 speed manual boxes are often worn at the bottom of second. But probably mounts, back one can just come loose and front one sometimes does better with a space between the mount and the body.
    Where is the exhaust hitting, middle of the car, or back box. middle of the car is related to your engine mounts rear box should have two rubbers on it and another one that looks like a rubber doorstop between the muffler and the bottom of the floor.
    They are noisy cars, put a thick removal blanket under the carpet and up to the dash along the firewall . Cuts out heaps of noise
    Quote Originally Posted by Golf Loon
    Or find a wrecked diesel and get the soundproofing out of that.
    Camden, Sydney
    If you find a wrecked diesel, you should be keeping engine mounts, diesel tank and clutch and flywheel, all of which go nicely in an uprated petrol car.
    Diesel clutch
    The diesel clutch has extra springing supposedly to absorb the vibrations of the diesel engine. I'm not convinced of the need but it's definitely more capable of handling the diesel's torque. I would highly recommend it too, Looney.
    Camden, Sydney
    GTIs, 16vs and Diesels had bigger clutches. The Diesel is the easiest to get in Oz.
    yeh i dont mind the noise i just wanted to see that i wasnt alone in the fact that it is noisy. but i will check out the exaust and engine mounts..... thanks guys
    SPC Guest
    You are not alone,
    my cabriolet is very noisy, mainly engine and exhaust noise, I am going to have to do some serious soundproofing. Might try the romoval blanket suggested above.
    Also noticed in my restoration manual that they actualy fit a proper golf soundproofing kit. foil covered foam adhesive pads which seem to go on the inside of the panels in the engine bay, bonet, and rear hatch. I wonder if anyone has experience with these?
Similar Threads
  1. resnonating driving me nuts
    By tommymac in forum Mk2 Golf & Jetta
    Last Post: 18-05-2007, 10:11 AM
  2. funny noise while driving!
    By GoLfMan in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 27-01-2007, 08:17 AM
