Results 31 to 33 of 33
Thread: Sump
  1. #31
    Feb 2006
    Perth Western Australia
    Quote Originally Posted by Spyda View Post
    I fitted it today and i think i may be over doing the ride hight.
    Lets start with the old sump, can you spot the problem?:
    ummmmmm......
    Its 22mm off the ground and thats a bottle cap, sorry for the bad pic. I hope that it doesnt cause any major problems or anoyances.
    Time will tell.
    how do you go with bump steer with the A arms at that angle Spyda? just curious
    77 Golf tarmac rally
    89 porsche 911
    80 Rabbit 4dr
    11 mk1 and 2\'s in various states of undress
    KEEPING THE BIG CUBES IN THE REAR VISION MIRROR
  2. #32
    Feb 2007
    Quote Originally Posted by Volksee77 View Post
    Exactly what i was saying mate, being this low and hitting something will most likely (and really unfortunately) result in breaking off the oil pickup. I would hate to see another mk1 wrecked. When welding the reinforcing on unfortunately you are only welding it to the sump itself which will still bend if you get a proper hit. Can i suggest making a bracket which bolts to the block via the sump bolts front and back hence any load is taken by the much stronger block?
    Not a bad idea mate.
    The engine is old and tired so if it gets smashed its no skin of my ****, i wouldnt throw the mk1 away. A broken engine just gives me more motivation to put the 1.9 in.
    The bump steer is alot worse than in the mk2, i guess its the power steering, but its bareable. It doesnt bother me and i dont go drive to fast so i dont feel its to dangerous either, well atleast compared to the mk2. Alex da man is sending me a tie rod flip kit to help it out a bit though.
    I need to modify the coilovers so i can bring the camber out more, the camber wear has almost made the front tyres bold on the inside.
    MK1 GLS 3door
    A4 B7 2.0T
  3. #33
    Jun 2007
    Eastern Suburbs Melbourne
    short chassis with very stiff coils aren't a great combination with extreme a arm angles.
    Mine arne't quite as bad as spyda's, but close enough. I don't find it too bad either, I've been through a few corners and few twisties, and unless you're driving 9/10ths+, it's not much of an issue on the street. the bumo steer isn't bad enough to completely throw you off course or anything./
    i like volkswagens
