Results 1 to 6 of 6
Thread: Stripping mk1 deadener
    Jun 2008
    Hobart, TAS
    Hey all,
    Quick question, does anyone know a good method or substance for removing the old sound deadener/protective coatings on firewall, spare wheel well, etc?
    Or is it just a matter of continuing with the old screw driver and determination?
    Any method appreciated,
    Dec 2008
    Perth
    heat gun works really well,
    have also heard dry ice makes things very easy but haven't used the method myself
    merry christmas
    Dan
    Point Cook, Vic
    as above dry ice or heat gun.
    Ive used the heat gun with great success. You heat it up very hot then let it cool a bit and it just peels off in one piece.
    FOLLOW US ON FACEBOOK
    Gosford Central Coast NSW
    or if mechanical means is all you can do, a 5" grinder with a stainless twist knot wheel (cup brush) is also good - takes offthe paint and rust aswell.
    Merry Christmas Mk1 dubbers!
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Jun 2008
    Hobart, TAS
    Cheers guys! Have been using the disc on most stuff, but the black tar-like seems to clog the disc, so will have a razz with the heat gun.
    Cheers and merry Christmas
    Oct 2005
    Nowra, NSW
    Heat gun and a scraper works fairly well, just not to much heat or the stuff melts and gets really messy.
    I've done it on two cars, the one with rusty floors took a lot longer than the one with good floors.
