My Dad has a Mk1 track car with 16v and has no problem with the diesel uprated mounts and has no problems. IS it maybe the car is driven in traffic with lots of start stops?
Hi all!
I am currently running my 3 forward engine mounts as prothane and the rear gearbox mount as a rubber diesel mount. I was wondering if anyone knew of any mounts that are stiffer than the standard ones but not as rigid as the prothane ones. The theory of the prothane mounts is great but I think the benefits are overrated.
As I mentioned, my rear gearbox mount comes off a diesel Mk1 Golf and is supposed to be slightly stiffer than the petrol version and I much prefer it over the rear prothane mount in regards to vibrations through the body! Anyways, any ideas as to where different stages of mount can be purchased for the mk1 as can be done for the later golfs?
Any advice much appreciated,
Tom.
Mk1 2dr ABF
Don't know the exact engine mount setup on a MK1, but with certain MK2 engine mounts you can get Polyurethane inserts/stiff-ners.
Like these actually,
GermanAutoParts.com
MK2 - *Insert list of dealer purchased extra's/standard features here*
80 series - The MK2's BIG, Sooty, polar opposite...
HAHAHA
Just purchase a full set of higher durometer rubber mounts from Techtonics.
TT H.D. motor mount kit Mk1 Chassis 1979-1993 set of 4 [199 150] - $100.00 : Techtonics Tuning, VW and Audi Performance Tuning and Repair Parts
Remember quality comes at a price.
Lots of MK 1 Scirocco's...
Cheers,
Grant...
I have BFI stage 2 mounts, stopped my 16v shaking around.
BFI MK1 Stage 1 Performance Motor Mount Kit BFI MK1 Stage 1 Performance Motor Mount Kit RABBIT GTI CADDY CABBY TRUCK GOLF
Not sure if you have resolved this yet, but I can tell you right now if you want to get rid of nearly all of the harshness from those red poly mounts, just pull out the inserts from the drivers and passenger side mounts - the 2 round mounts. Leave the front and rear poly mounts there. These 2 inserts are where nearly all of this harshness comes from with these cheap red poly mounts. I just got back from a test drive where i removed those red inserts and what a difference.
To give you an indication of how much difference particularly the drivers insert makes - I was not even running the whole insert, I had cut off the very top insert piece and that was all that was inserted into the drivers side rubber mount. The difference with just that piece gone is really significant. If you do this you might want to fill all the holes in the rubber mount with sikaflex and let it cure just to increase the longevity, and make them a little bit more rigid. Anyway there is a possible solution and its free.
