Results 1 to 8 of 8
Thread: Steering woes
    Apr 2006
    Melbourne, Victoria
    Steering woes
    Hi everyone,
    Now that ive got my GLD back on the road, it seems to have worn out while it wasnt being used. There is a very slight wobble in the steering wheel at some speeds that becomes pronounced when cornering to the right at speet (diesel speed that is). Ive checked the front tyres and they appear to be sound.. Also it had a wheel alignment 10k kms ago. It is steering slightly to the right also.
    Any ideas for further investigation are much appreciated.
    Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
    White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
    Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
    blackgti1.8 Guest
    Hmm - check all your steering ball joints for starters - there's a ball joint on
    each end of both steering arms. Then check steering rack pinion adjustment, and the bush in the (near-side) end of the steering rack.
    Also check the ball joints on the wishbones as well...
    Basically, look for anything loose
    Apr 2006
    Melbourne, Victoria
    Thanks blackgti
    Camden, Sydney
    Tie rod end I suspect
    May 2006
    Maryborough Vic
    Talking
    check your tyre pressures aswell
    if you can't find anything mechanical wrong
    rotate your tyres see if it changes
    the reason cars pull left or right 80 % of the
    time is tyres
    i'd suspect the tyre wall has gone soft if you
    haven't used the car in a while, a definate if you
    have wobble at low speeds eg : 0 to 40 kph
    Apr 2006
    Melbourne, Victoria
    Thanks dudes,
    I had the car up yesterday and checked for anything loose or with play and couldnt find anything. Ill next rotate the tyres. Could it be the strut top bearings and how do i check them??
    Matt
    Melbourne, Australia
    Also how you do the wheel nuts up is important, it has to be opposites to make it even.
    88' Volvo 760GLE
    88' Volvo 740 Turbo
    Quote Originally Posted by tosspot View Post
    Also, drags are the worst form of motorsport. Who'd want a fast drag car for their street car?
    Apr 2006
    Asaka-shi Saitama Japan (from Tassie)
    also worth a look is how much play is in your steering rack.
    my MK1 didnt wobble, but it had about a quater of a turn before it had any input, lol.
    the rack wears a bit and the pinion becomes loose fit on the rack.
    easy to ajust tho
    Cheers, Benny
    www.axesent.com.au
