there isnt enough room to swing a spanner, but you can do it anyway. welcometo the world of mk1 service.
a couple of tips for this particular job:
1) slide the boot right out of the way towards the end of the tie rod
2) i have 2 modified shifters i use for this particular job - one is an 8" that i have ground the inside of the jaws so it will actually fit over the lock nut, and the other shifter (also an 8") i cut half of the handle off to make it nice and short. this means you can get it in there more easily.
a couple of modified shifters work for several "VW special tool" applications.... and you only need to buy really cheap ones![]()
