Results 1 to 10 of 12
Thread: Steering rack
    Aug 2006
    Upper Ferntree Gully Victoria
    Steering rack
    Hi could someone please advise me if the ball joint on the rack end Of the tie rod is adjustable for wear or disposable
    Thanks in advance Trevor
    MK1 RALLY CAR
    SUPERCHARGED MAZDA323 AUTOCROSS CAR
    Jul 2005
    Melbourne, Williamstown
    You can get the re rolled I'm told.
    mk2 GTi 16v
    Corrado G60
    Apr 2006
    Hobart,Tas
    new tierods are pretty cheap these days. I would replace it. cheers!
    Aug 2006
    steering rack
    Thanks for your replies dumb question are tie rods available as a spare at vw dealers ? The ones I ring carry almost nothing for mk1's Cheers
    MK1 RALLY CAR
    Boronia VIC
    Try John at VolksBaru in Noble park he'll soon track 'em down for you.
    Pete
    Aug 2006
    Thank for the info
    MK1 RALLY CAR
    syncro Guest
    Quote Originally Posted by gumbootracing
    They don't carry anything for any VWs nowadays.
    You have to order it in.
    Apr 2006
    Hobart,Tas
    non VW dealers ie. independent VW workshops are the place for earlier parts. I think the Bilstien ones I have in stock retail for around $75-$90 each. Can't remember of the top of my head as I am not at work. Boots are extra.
    Cheers, Andrew
    syncro Guest
    You have to be careful with aftermarket stuff for VWs as most of it is garbage.
    Bilstein=very good.
    Hey Trev, Peter (canbera vw) had some when I needed them, he may still have some out the back. The re-fit was a easy enough.
    C
    It's been a while...
Similar Threads
  1. steering drivetrain and heartache
    By gldgti in forum Mk1 Golf
    Last Post: 04-06-2006, 09:25 PM
  2. Rack Ends solution. steering rack problem fix
    By Edison in forum Mk1 Golf
    Last Post: 10-05-2006, 09:27 AM
  3. Power steering rack MK1?
    By 82cab in forum Mk1 Golf
    Last Post: 23-04-2006, 07:52 PM
  4. New improved dynamically variable steering!
    By Peter Jones in forum Mk1 Golf
    Last Post: 22-11-2005, 09:56 PM
