Steering Rack
Advice please?
The LH knuckle on my steering rack has a good 10 - 15mm play.
Before I pull it out & investigate: what is the best fix here?
Cheers.
Replace it.
The whole rod unscrews from the rack and can be purchased as an assembly.
The RHS side one is adjustable, the LHS one may not be, but can be replaced with a RHS one making both adjustable.
If the rod has he adjustable ends you can replace just the end.
Andrew (gtimk5) might have some for sale.
Here's the old and new from my car.
![](http://www.vwwatercooled.com.au/forums/images/imported/2008/03/w8-1.jpg)
Pete
Thanks Pete.
Replace it is!
- You may not post replies
- You may not edit your posts
Forum Rules
