Check the steering shaft below the column, between the column & the rack. The universal joint may be seizing up. Replacement required if so.
CV joints will give a clicking noise only, not a whine. Spin each wheel with your fingers on the backing plate. If you feel any thing through you fingers it usually means a crook hub brg.
Outer cv joints are usually $115-$130ea
Hub Brgs approx $50-$60 ea
