Results 1 to 2 of 2
Thread: Starting Issue
    Sep 2009
    Chillaxing in Tas
    Starting Issue
    Trying to start the golf today for the first time since i put a mk3 1800 in her.
    If i pull dissy out and spark plugs, the engine turns over fast,
    Put dissy back in and it does same thing
    Put plugs in but no leads on, it turns slower
    put leads on and wire from dissy to coil and it struggles to turn over.
    Ive doube checked all the timing, everything is set to TDC. Most parts are new.
    One thing i noticed is im missing the second wire to starter motor, where should that connect?
    <space for rent>
    Sep 2009
    Chillaxing in Tas
    SORTED!!! turns out i put wire from dizzy to coil on the + side
    <space for rent>
