Results 1 to 10 of 11
Thread: stalling 1.6 mk1
    sydney
    stalling 1.6 mk1
    stalling at low revs starts fine drives with hesitation aint idling for crap. seem to have good spark in dizzy. where too now
    help
    syncro Guest
    Clean the idle jet.
    Check the idle solenoid.
    imported_brackie Guest
    Agreed
    While you're at it, also check all vacuum hoses and PCV valve.
    Golfwise Guest
    Check the rubber mounting block. They crack and let in air.
    !.6 carbies were below average and have always given trouble since new.
    Read a workshop memo from VW back in the 70s re carbies stalling stating that even the factory couldn't rectify the problem and later changed to a different carbie or F/inj.
    Some have a solenoid on the pilot jet so check that one as well
    Good luck
    sydney
    it seem a little more drastic that idle managment as as soon as i let the revs drop the engine stalls even when down shifting.i ran out of petrol last week, could this have an effect eg crap from the bottom of the tank in the lines or the pump??? thanks for all the help
    Golfwise Guest
    Cut off solenoid by the sounds of it.
    Could be a blown fuse ,check that you have power to the solenoid.and check the earth too.
    Its the cylindrical thingy on the passenger side of the carby with a wire running to it.
    syncro Guest
    Where in Sydney are you?
    sydney
    and the award goes to syncro first and the wise one second, fuel cut off solenoid it was, all good now. thanks for all the help
    good to know you fixed it
    Camden, Sydney
    Its always the damn solenoid, or the wire. Just cut the end of the solenoid off, or put a bolt in. To stop overrun give it a rev as you turn it off.
    I hate those carbies, they are cr*p. What about your twinnies?
Similar Threads
  1. Mk2 Cabriolet stalling all the time
    By Itshercabriolet in forum Mk3 Golf & Vento
    Last Post: 23-02-2006, 09:36 PM
