Ok so bad news, car doesn't work. Won't run and wont start and it can get ****ed.
Got the res and tip put on at the exhaust shop and then spent 4hrs trying to get it to start, got a wheel alignment and sloooowly drove it home where it broke down 5min from home and i spent another 2hrs tryin to get it running again. Funny thing was it drove without issue to the exhaust place.
A few people suggested the dizzy is stuffed and its getting to much fuel with the ****ty fuel pump so today i bought a 5psi Carter rotary vane pump, almost the same as what Pete Jones runs on his race car but from what i understand his has a higher pressure. I mounted it the same way he did. The pump is a lot less noisy than the other one, just a slight hum rather then DAK DAK DAK DAK!
Pete was also kind enough to lend me a working dizzy that i will pick up tomorrow. Hopefully it does the trick and i can get this box to SEDF at least.
I hate being a shiz kent at this!!
This is how Pete mounted his:
