Results 1 to 10 of 219
Thread: Spyda's Mk1
Spyda Spyda's Mk1 10-08-2010, 08:03 PM
Spyda I havnt realy taken alot of... 10-08-2010, 08:04 PM
Spyda Building up the sterio, its... 10-08-2010, 08:05 PM
Spyda Fun. If you look closly... 10-08-2010, 08:06 PM
Spyda The SD motor, coming out in... 10-08-2010, 08:10 PM
Spyda So far the motor has been put... 10-08-2010, 08:15 PM
koztek55 man i cant wait til its on... 10-08-2010, 08:23 PM
Gipson looks the business dude can i... 11-08-2010, 09:51 PM
Spyda In the OP man. 165/55 r14... 11-08-2010, 10:24 PM
velly_16v_cab i love this car...keep it up... 11-08-2010, 10:44 PM
thestu Cheers dude!! We shall sort... 17-08-2010, 06:29 PM
Spyda Hit another speed bump. I... 18-08-2010, 08:07 PM
GeorgeMK1 :rolleyes: Murphy's law.... 19-08-2010, 02:55 PM
Spyda Well one late night and an... 20-08-2010, 05:35 PM
thestu Doing good man!!! :D 27-08-2010, 07:45 PM
thestu Well done bro!!! Keep... 28-10-2010, 07:08 AM
Spyda 18days till DOVW, which means... 03-11-2010, 08:50 PM
Jace I wish I was a stereo guy. :(... 03-11-2010, 08:55 PM
WABIT lol lucky you did the engine... 03-11-2010, 09:02 PM
MeeM Agreed. Sometimes, paying... 03-11-2010, 09:03 PM
Water Boy Sick bass... 25kw gain... 03-11-2010, 09:15 PM
Jarred beast of an update! can't... 03-11-2010, 09:23 PM
thestu **** man. :( if I could help... 08-11-2010, 07:22 AM
DubSteve Good luck bro your almost... 08-11-2010, 08:56 AM
Spyda Not much to report. Got... 16-11-2010, 05:21 PM
Jace I use the steelies daily.... 16-11-2010, 07:22 PM
thestu Best EVER! 21-01-2011, 04:38 PM
Spyda Here we go, The system is... 21-01-2011, 05:48 PM
Spyda Its all these little bits... 21-01-2011, 06:00 PM
Jace New chrome does wonders huh!... 21-01-2011, 07:39 PM
Jarred wow, you've been a busy boy... 21-01-2011, 08:24 PM
thestu I realized after we did it... 29-01-2011, 07:23 AM
Volksee77 could be the crank seal... 29-01-2011, 11:26 AM
Spyda hahaha :P Ill check for... 29-01-2011, 01:08 PM
Jarred try and set is at standard... 29-01-2011, 03:08 PM
Volksee77 yeah if it's been sitting for... 29-01-2011, 03:24 PM
GRN_VAGN Pretty certain it only goes... 29-01-2011, 03:39 PM
Spyda Thanks for the help guys, ill... 29-01-2011, 05:08 PM
Spyda CALL THE VATICAN, WAKE THE... 30-01-2011, 04:07 PM
thestu Wicked job dude!!!!!! 30-01-2011, 05:13 PM
Spyda Nothing on TV and killing... 30-01-2011, 07:10 PM
Jarred nah it's good man, always... 30-01-2011, 09:17 PM
Spyda Did the timing today, exactly... 31-01-2011, 05:52 PM
thestu :( Are the jets in the... 31-01-2011, 05:59 PM
Valver. Have to say again, you're... 31-01-2011, 08:18 PM
Spyda Yeah man, i think so. I... 31-01-2011, 08:45 PM
Spyda Ok so bad news, car doesn't... 03-02-2011, 08:19 PM
    Feb 2006
    Perth Western Australia
    could be the crank seal allowing a litle oil into the clutch or it is just starting to slip or........................your engaging the clutch like a girl and wearing it out big time
    77 Golf tarmac rally
    89 porsche 911
    80 Rabbit 4dr
    11 mk1 and 2\'s in various states of undress
    KEEPING THE BIG CUBES IN THE REAR VISION MIRROR
    Feb 2007
    Quote Originally Posted by Volksee77 View Post
    hahaha
    Ill check for leaks but i drove it for about 20min today, longest since i put the engine in, and it didnt smoke. Keep in mind the engine was sitting around for a few years.
    Lots of other problems but its drivable.
    Gota get a timing gun. Does anyone know what the timing should be set at? Is there some retard or advance that has to be set?
    MK1 GLS 3door
    A4 B7 2.0T
    Jun 2007
    Eastern Suburbs Melbourne
    try and set is at standard for now i reckon. (Hope you put the flywheel on the correct way up!¬)
    Hopefully the vac advance will sort everything else out.
    i like volkswagens
    Feb 2006
    yeah if it's been sitting for ages it could be build up or paint giving off a little smoke as the heat doesn't exactly dissipate from that area easily
    89 porsche 911
    80 Rabbit 4dr
    Sep 2009
    Chillaxing in Tas
    Pretty certain it only goes on one way as 2 bolts are closer together.
    and i think stock timing is between 6 and 8BTDC.. i usually go 8 as i do more town driving and run premium fuel. so its snappy
    <space for rent>
    Feb 2007
    Thanks for the help guys, ill give the timing a shot on Monday. Car is at my mates shop getting the rust fixed.
    MK1 GLS 3door
    A4 B7 2.0T
    Feb 2007
    CALL THE VATICAN, WAKE THE POPE, ALERT TOM CRUISE.
    30yr old standard mk1 with NO RUST IN THE PILLARS!
    Found very minimal rust when replacing the front windshield rubber.
    Front end all together
    Got the car back today, rust repaired on the arch. Fantastic job i reckon im happy with it.
    MK1 GLS 3door
    A4 B7 2.0T
