Page 9 of 22 FirstFirst ... 789101119 ... LastLast
Results 81 to 90 of 219
Thread: Spyda's Mk1
  1. #81
    Aug 2009
    Make your own rubber gasket maybe? Mine works just fine.
  2. #82
    Feb 2007
    Quote Originally Posted by Jace View Post
    Where did you get the rubber gasket stuff from? I only ever go to autobarn so i have no idea but i think it would be ideal over the paper stuff.
    MK1 GLS 3door
    A4 B7 2.0T
  3. #83
    Aug 2009
    Quote Originally Posted by Spyda View Post
    Just like 1.5mm neoprene rubber from Clark Rubber. Not like it's a vital gasket like a head gasket. Just needs to be air and fuel tight, right?
  4. #84
    Feb 2007
    Thats my guess, ill give it a shot if the sylicon doesnt work.
    MK1 GLS 3door
    A4 B7 2.0T
  5. #85
    Camden, Sydney
    Carefull you dont suck silicone into the carby mate, that will stuff it right up.
    If the carby is a webber it is proablly a generic webber gasket. Draw a template of what you want and take it to a proper old school car shop. You will probably find that its the same as the gasket on an old escort, or holden, or something with a webber and thats what you need to order. Sounds like you are getting close mate, keep at it.
  6. #86
    Sep 2009
    Chillaxing in Tas
    Feb 2007
    haha sweeet, thanks man, ill buy a few!
    MK1 GLS 3door
    A4 B7 2.0T
  8. #88
    Feb 2007
    ****ed up prity hard today.
    I went and got some gasket maker and while taking the carbie off a nut or washer fell in to the manifold. I didn't notice until i put everything back together and started the car. It made its way past the valves and in to the block smashing the spark plug in cylinder 1.
    One step forward and two large steps back. Stupid cars.
    MK1 GLS 3door
    A4 B7 2.0T
  9. #89
    Jun 2007
    Eastern Suburbs Melbourne
    BUGGER!
    any other damage?
    I did that once. Ended up with a valve sideways in a piston.
    i like volkswagens
  10. #90
    Aug 2009
    ****! How far do the valves open? Might be okay? Maybe? Mmmmaybeee?
