Make your own rubber gasket maybe? Mine works just fine.
Carefull you dont suck silicone into the carby mate, that will stuff it right up.
If the carby is a webber it is proablly a generic webber gasket. Draw a template of what you want and take it to a proper old school car shop. You will probably find that its the same as the gasket on an old escort, or holden, or something with a webber and thats what you need to order. Sounds like you are getting close mate, keep at it.
WEBER 32/36 CARBY BASE MOUNTING GASKET ESCORT/CORTINA - eBay Window Cranks, Interior, Car, Truck Parts, Cars, Bikes, Boats. (end time 20-Oct-10 07:41:25 AEDST)
They will work mate, and cheap buy a couple for spares
<space for rent>
****ed up prity hard today.
I went and got some gasket maker and while taking the carbie off a nut or washer fell in to the manifold. I didn't notice until i put everything back together and started the car. It made its way past the valves and in to the block smashing the spark plug in cylinder 1.
One step forward and two large steps back. Stupid cars.
MK1 GLS 3door
A4 B7 2.0T
BUGGER!
any other damage?
I did that once. Ended up with a valve sideways in a piston.
****! How far do the valves open? Might be okay? Maybe? Mmmmaybeee?
