Page 21 of 22 FirstFirst ... 1119202122 LastLast
Results 201 to 210 of 219
Thread: Spyda's Mk1
  1. #201
    Feb 2007
    Quote Originally Posted by GRN_VAGN View Post
    might sound weird, but double check timing belt and all timing marks again.
    My first 1.8l did same thing as yours, turns out cam was 1 tooth out.. it ran and revved fined... but it would hold idle and when it did it was 1400rpm
    It it hydraulic lifter? maybe one is sticking and not getting valve open fully.
    Might just be something very small
    Cheers mate, ive checked timing 100 times but i dunno how to get the teeth 100% right on the cam as all it says its the mark has to line up with the rocker cover.
    Its a hydraulic head off a mk2 gti, ill check the valves if it doesnt drive tomorrow.
    If it drives ok then i will take it to a pro next week and get it all done properly, im sick of pretending like i know what im doing.
    Any recomendations?
    MK1 GLS 3door
    A4 B7 2.0T
  2. #202
    Aug 2006
    Melbourne VIC
    Have you got the fuel presure regulator set at 6psi?
  3. #203
    Aug 2006
    Melbourne VIC
    Also needle and seat? Main jet blocked?
    When comes off chock there is a blockage?
  4. #204
    Sep 2009
    Chillaxing in Tas
    yeah i got a 1.8L from a mk3. the timing for cam is a bit easier as it has a arrow on a plastic bit to line up with
    Not sure whats wrong, mine was same cold or hot..
    <space for rent>
  5. #205
    Feb 2007
    Quote Originally Posted by Water Boy View Post
    Was told i dont need a FPR, i was also told the carbie was fine. Im not using the choke because when i did it got hot and at one point melted a bit.
    Also forgot to mention that it runs the same hot or cold now.
    At the moment i just want to get it to the show, after that im giving it to a pro because im done stuffing around with it. It was ok giving it a go and learning a few things along the way but its getting to the point where i dont have the time and pacients as well as the knowledge. I also need a car to drive around as dads merc needs work so we are sharing the polo.
    MK1 GLS 3door
    A4 B7 2.0T
  6. #206
    Feb 2007
    The gf got this done:
    MK1 GLS 3door
    A4 B7 2.0T
  7. #207
    Aug 2009
    That's awesome, but does it help your car go broom-broom?
  8. #208
    Feb 2007
    Quote Originally Posted by Jace View Post
    lol if you think about it....it does.
    MK1 GLS 3door
    A4 B7 2.0T
  9. #209
    Aug 2009
    Quote Originally Posted by Spyda View Post
    Haha, good luck riding that to SEDF.
  10. #210
    Jan 2008
    Strathfield,Sydney
    Ok so bad news, car doesn't work. Won't run and wont start and it can get ****ed.
    Got the res and tip put on at the exhaust shop and then spent 4hrs trying to get it to start, got a wheel alignment and sloooowly drove it home where it broke down 5min from home and i spent another 2hrs tryin to get it running again. Funny thing was it drove without issue to the exhaust place.
    A few people suggested the dizzy is stuffed and its getting to much fuel with the ****ty fuel pump so today i bought a 5psi Carter rotary vane pump, almost the same as what Pete Jones runs on his race car but from what i understand his has a higher pressure. I mounted it the same way he did. The pump is a lot less noisy than the other one, just a slight hum rather then DAK DAK DAK DAK!
    Pete was also kind enough to lend me a working dizzy that i will pick up tomorrow. Hopefully it does the trick and i can get this box to SEDF at least.
    I hate being a shiz kent at this!!
    This is how Pete mounted his:
    hey dude in regards to the pump im guessing its possible to do a similar mounting with the original cordoba style pumps??? mines just the square type at least i think it was the factory one. Was thinking about mounting mine on the underside towards the front but that pic makes me think the back perhaps.
    76 Scirocco
