1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
20W50 is what you want.
Make sure the oil to water cooler is not leaking internally. I am not sure how often Frank has run this car but the cooler ended up leaking some time ago ( water in the oil etc) From memory Frank changed the cooler and flushed the engine oilways and cooling system.
As long as the basics are right you will get home fine.
Engine pic of car.. Taken in Dec 2007
Lots of MK 1 Scirocco's...
Cheers,
Grant...
cheers for the pic grant !!! im going to take the toyota fj75 for a run with a car trailer on the safe side , but mite be tempted to have a spin half way home !!! will be asking frank about the cooler ! he hasnt been running it for the last 3month , its been in dry storage......
apparently ... i just spoke to the owner , he says he has bypassed the the oil cooler ? would this be ok ? is there a variety of oil coolers that will suit , or go with a vw type ....
what would be a sufficient radiater for a kr 16v ? im thinking of getting a spare , would the mk1 be limited for space or should i just stick with a mk2 radiater ??
