Results 1 to 9 of 9
Thread: So the golf was running a bit shi**y
    Apr 2010
    brisbane qld
    And i was having a look over it took the oil cap off and theres a white cheese.
    Headkgasket im thinking not overly happy with this !!! How hard are they to do
    being single cam easy i assume ? Is there a gasket and valve kit i can get ?
    Any help will be appreciated,
    Julian
    headgasket is pretty simple, just lining up the cam belt is the important part.
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
    Apr 2010
    brisbane qld
    Can anyone suggest somewhere in brisbane to get the parts needed ? Is there anything else i should do since im taking it to pieceS?
    Apr 2010
    brisbane qld
    woah crazy **** would you try it ?
    Boronia VIC
    I wouldn't go near the stuff.
    I just had to replace every part of the cooling system on a B1 Passat because someone had used 'miracle cure' to stop a radiator leak.
    All the hoses were crunchy and the water pump was stuffed!
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Jul 2005
    Newcastle, NSW
    Call Tooleys Imports in Hornsby NSW and they will sort you out.
    Quote Originally Posted by julian_s13 View Post
    I have !! It worked great.
    My old Mk2 had that stuff in there, it is still running AFAIK
    If you are confident to replace HG go for it, otherwise at worst you won't lose much money if this product doesn't work for you.
    Apr 2010
    brisbane qld
    Ok so ive just decided im going to do the headgasket properly, now im in need of a 2 - 3mm headgasket, does anyone knwo wher i can purchase one of these ? Also i have arp headbolts in it at the moment do i need to replace these or can i reuse them ?
