Results 1 to 6 of 6
Thread: Smokey engine: replace or recondition?
    Miami Guest
    Hi Folks!
    First up, great forum. Been lurking for a few weeks, this is my first post. Hope you can help keep my golf on the road.
    I've got a '77 gls and recently it's been leaving bigger and bigger clouds of white smoke when i start up or pull away from the lights. I read somewhere it could be the valve stem seals? The motor still pulls well and doesn't smoke under acceleration.
    As i don't have the skills / tools / space for an engine rebuild, should I:
    Search around for a good secondhand engine ( i hear some Seat units slot in without out too much fuss)
    Or should I bite the bullet and have the engine reconditioned. Anyone know a good place in Sydney?
    Which would be cheaper / easier?
    The whole car is totally original except for a 5 speed 'box and it's only done around 150K, but i'm not too worried about keeping the engine original.
    Anyway, all thoughts / advice would be much appreciated,
    Thanks a lot,
    Miami
    Sunny Coast - The QLD
    Hey dude. I have a Mk3 2L 8v that was rebuilt 6,000 km ago that I can sell you if you want. It has a bit of a crazy cam and will bolt straight in. Email me if your interested.
    eggers6@gmail.com
    MK1 floG soon to have 16v 2L with cable change gbox - need a 16v turbo manifold
    "Fit the gearbox ya bum." Loon - best post ever!
    Aug 2007
    Wink
    Go the engine dude sound by the description its heavy blue and not white smoke mate there is a distinct difference with regards to engine problems.
    White- coolant
    Blue - Oil
    Black - too much gas
    Cheers but go the engine mate i reckon. Plenty out there and by the sounds the dude posting here has u sorted mate!
    Alba European
    Miami Guest
    Thanks for the advice fellas.
    Gotrice, I've sent you an email.
    Apr 2006
    Melbourne, Victoria
    Ive got a spare GLD badge you could put on the back
    Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
    White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
    Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
    G'ady Miami 7 welcome to the world of VWW.
    If it is only smoking with high manifold vacuum (crusing, on deceleration, going down a hill, sitting at light's for an extended period, starting up cold & hot etc.) & not using bugger all oil, I'd say it is the valve stem seal's.
    Which will only require a cyl. head reco (a replacement engine is abit over the top). They will probably replace the valve guides too, as these are prone to wear out as well.
    A good full head reco. off the street should be around $450 - $500 if you can remove & refit the cyl. head yourself.
    If not, add labour which would be around another $600+ incl. part's.
