I'm pretty sure you have wired it the wrong way around. Sounds like you wired up to the low beam. Can't remember which wire colour is which but whichever one has 12v "ONLY" when high beam is on is the one you want. If you have a test lamp or multimeter just probe the pins on the main headlight plug, get someone to flick high beam on and off.
Also, when you flick high beam on and you haven't let go off the headlight lever (its still pulled towards you), you momentarily have both high and low beam on. That might be why you mixed them.
