Quote Originally Posted by gtimk5 View Post
You replaced the speedo cable last weekend. Did you make sure to swap the "O" ring onto the other cable??
Cheers, Andrew
Andrew, the leak was there before I swap the cable. I'll check if the leak come from the speedo cable. I didn't know there is any o-ring
