Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Service parts
    Jan 2010
    west melbourne
    just curious what i need to replace my clutch, imparts has the clutch and throwout bearing but didnt seem to have the rear main seal, clutch cable or bolts? is there a local stockist for these or do i need to order from o/s for these?
    Driving the coal. Low and rattly.
    Gosford Central Coast NSW
    toolies have clutch kits with friction plate, pressure plate, spring plate and retaining spring and you can buy the flywheel bolts separately if you need new ones. last time i needed one HSY had the cable and i know both places will have the bearing. also you should try and do the rod bushing and seal. Tooleys have these (last time I checked anyway).
    Ring around.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    vic
    As it has been mentioned before that Toolies don't do OEM brands. Are they just not OEM or real 'cheap' quality?
    Does the same go for ASV???
    not really the case at all. tooleys do so many parts its rediculous, and much of it is OEM. For instance they sell
    : Sachs, boge, bilsten/febi, elring, mann&hummel, hengst, continental, bendix, etc etc etc.... all of which are OEM for one thing or another.
    I'm not a mechanic, but I probably spend about 2k a year at tooleys and nothing i've bought from there has been anything less than I expected it to be.
    between hsy and tooley's i can usually get anything i need and the only time either has let me down was some ****ty non-OEM mk1 strut tops that HSY sold me once.
    '99 A4 Quattro 1.8T
    Jan 2010
    west melbourne
    thanks alot glddti! very helpful
    vic
    yeah. cheers dude! I just wasn't sure, as previous posts of other users were quite short. I guess I'll see how I go with them and give the other suppliers a try in the future as well.
    I guess they are pretty much all the same price I would guess...
