toolies have clutch kits with friction plate, pressure plate, spring plate and retaining spring and you can buy the flywheel bolts separately if you need new ones. last time i needed one HSY had the cable and i know both places will have the bearing. also you should try and do the rod bushing and seal. Tooleys have these (last time I checked anyway).
Ring around.
