Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Running on 3 cylinders
  1. #21
    syncro Guest
    Run a hotter plug in #3 and see what happens.
  2. #22
    Dec 2005
    Thanks syncro, I bought a hotter plug today. Bosh w10 instead of the w7 that was in there..... no longer runs on 3 and doesnt miss at all :twisted:
    This has been the best the car has ever run. Thrashed it quite a bit just before and it didnt miss a beat, so hopefully it will stay that way :roll: ... my car was booked in to the mechanic tomoz, but it longer needs to.
    edit:
    I also took some water pipes off towards the heater in the dash and cleaned em out, now the heater works and the car runs MUCH cooler. I may have a leak in the dash though as there seems to be coolent under the center console.. unless it was from when i flushed it out.. time will tell.
  3. #23
    imported_brackie Guest
    Good result
    Well done! Progress. Hope that the water inside the car isn't indicative of a matrix leak. Thanks for the input, syncro
  4. #24
    syncro Guest
    It's a design fault with the manifold, only I cannot work out what would make #3 run rich.
    A lot of my friends had this set up many years ago, then converted to twin side draughts and got more power and better economy.
Similar Threads
  1. Running in a new diesel
    By brackie in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 30-01-2009, 10:29 PM
