Results 1 to 10 of 11
Thread: rocker cover gasket troubles
    Jul 2006
    Sunshine Coast....Moved up in jan 06 from Tas
    i have got a early mk2 GTi engine K-jet (EV) i bought a rubber gasket and when i changed it, the mounting holes were to small for the gasket to sit flush, and oil pissed out everywhere, i though i was going to have an engine fire.... ... any ideas??? have i got the wrong gasket??
    Jan 2006
    Ballarat, Victoria
    When I bought a rubber rocker gasket I found that the studs on the head had shoulders on them, so that the gasket wouldn't fit. I think the dealer should have supplied new studs when he sold me the gasket.
    Anyway, I drilled out the holes to the size that fitted, and played safe with black silicone, and the thing doesn't leak. Think that getting the correct studs would be a better idea than drilling a brand new expensive gasket.
    Camden, Sydney
    Use an early type cork gasket or get the later studs, like on a Mk3.
    Jul 2006
    that sounds right. i though about drilling them bigger.. i cant use the car as it is now so ill drill them bigger.. and i was looking for a cork 1 but no1 had any.. ive got gasket glue stuff. ill use that... stuff like this makes me want to get a new engine...
    Perth. WA
    Techtonics ( amongst other suppliers) does an upgrade kit for the cork gaskets,
    1 Piece rubber gasket and the correct studs for $20 US. ( part # 198.163 )
    good people , little bit expensive ...http://www.techtonicstuning.com/
    Did this on my last 1.8 rebuild ( 3 1/2 years ago) and it still doesnt leak. also changed to the rubber sump gasket with windage tray , all good stuff..
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    brackie Guest
    Old trick
    But it works When I was an apprentice I learned to smear cork gaskets with petroleum jelly (Vaseline) and let them stand for a while.
    This:
    * softens the surface and protects against initial shrinkage
    * allows them to stick to the surface of one of the components to be fitted
    *Lets you slide the gasket to get it exactly in place
    Unlike grease, petroleum jelly dissolves completely in hot oil and causes no residue.
    If I can't get a surface absolutely clean and free of indents, I smear a very light coat of silicone over the gasket. Silicone's great stuff as long as you use the absolute minimum necessary to do the job. I cooling systems too much will block the radiator core over time, and the last thing that you want is a chunk of it getting stuck in a crankshaft oil way
    Camden, Sydney
    i have untold new cork gaskets. $5 each to you blokes
    Dec 2005
    good price Loon
    I bought a couple off EBay UK for about $20 delivered
    Always handy to have a few extra laying around
    Jul 2006
    well i have to pull the rubber 1 off, so IF its f#$%e*d ill PM you for 1..
    Quote Originally Posted by silverMK1
    Err what about just pulling the studs and replacing with 6mm bolts?
    c
    It's been a while...
Similar Threads
  1. VR6 head gasket problems?
    By worm in forum Mk3 Golf & Vento
    Last Post: 26-04-2006, 12:51 PM
