Hello All
My 1.6 GLS will not idle at all. anything below 2000 revs and shes gone.
i have taken the carb (solex 34 pict 5) off and cleaned the ports jets butterflies and the body ,i noticed when i took the carb off that the inlet manifold has a around 20mm connection into it that has nothing on (basically a open pipe into the manifold i) can any one tell me what this is for? as i am thinking it should be connected to something or at least blocked off to stop air ingress ?????.
before this happened the car was running on after the ignition was turned off, now i believe this to be the cut off valve on the carb, does anyone know where i can buy one?
oh yeah the car is normally run on 98 but my girlfriend put 95 in before this happened (the no idle that is) do you think this could be a factor, i did add octane improver but it had no effect
thanks for your help i am new to this older VW stuff but loving every minute of it
Have a MK 4 1.8 20v turbo gti in the u.k
and my little gls baby here in Australia
