Results 1 to 10 of 10
Thread: Revving it's head off
    Feb 2007
    Launceston, Tasmania
    Hey Guys,
    Seems there is something wrong with my mk1 carby, now when it stopped everything is fine but when you start the car and press down on pedal, everything else works fine except the bigger throttle arm near the choke seem to seize open and won't return, big spring is still attached and everything returning normal exept that arm, and only when the car is started (not when ignition is off) in saying that once it's stuck it takes "some persuding" to get back to normal.
    Hope sombody can shed some light, i'm sure its a common problem.
    brackie Guest
    Strip down
    Quote Originally Posted by PuttPutt'76 View Post
    Hey Guys,
    Not you.. The carbie If it's getting that bad it's time to put a kit through it. No big deal.
    Feb 2007
    Quote Originally Posted by brackie View Post
    Hahaha, cheers. So i take it i'm not driving home from work today then .
    By a kit you mean new needle and stuff don't you. How much does this cost and who do you think could do it for me in Lonnie.
    Apr 2006
    Asaka-shi Saitama Japan (from Tassie)
    hey Daniel. If u ever get stuck for a lift back home just give me a call ...
    Cheers, Benny
    www.axesent.com.au
    Feb 2007
    Hahahaha, yer only just round the corner. Wouldn't have a spare carby laying about in you VW emporium would ya man?? hahaha. Maybe a weber or know anyoune that's got one goin cheep .
    Apr 2006
    lol. nope no spare carbies, ...cept 2 off suzuki sierras.
    but what u said on MSN about it all moving freely and working when the motor off...then it does it when the motor is on makes me think its a choke issue...some how the choke is jamming or somethings come adrift.
    like i said, try unpluging the solinoid n see what happens.....
    Anyone else got any ideas?????
    Cheers, Benny
    www.axesent.com.au
    Apr 2006
    actually no...derr me, unpluging the solinoid will make the choke stay on .... maybe a vacuum line off or worn...
    take the air cleaner off and dissconnect the choke linkage for now i recon..
    if that doesnt work start taking vacuum lines off and plug em with screws
    Cheers, Benny
    www.axesent.com.au
    Apr 2006
    any luck ???
    give me a call about 5ish tomorow if u have no luck. ill come around n have a look.
    Cheers, Benny
    www.axesent.com.au
    Feb 2007
    Quote Originally Posted by 86gti View Post
    any luck ???
    Ur a genuis Benny, Kinda. hahaha. It turns out with all my questionable wiring issues the power wire to the soleniod wasn't getting power, had a bit of a muck around and it works again. YAY!!!. While i was at it i figured out my choke was buggered and staying on all the time so THATS why it's been running like **** and using **** loads of juice. So puttputt is restored to is formed "glorious" self. hahahaha. SUPERTRENDY!!!
    Apr 2006
    hehe. long live putt putt!! good to hear!
    Cheers, Benny
    www.axesent.com.au
