Results 1 to 8 of 8
Thread: Reputable Webber carburator rebuilder
    Feb 2007
    I have a 32/36 webber off a ford escort that needs a rebuilt, does anyone know a good place to get it done and roughly how much it would cost?
    MK1 GLS 3door
    A4 B7 2.0T
    Jan 2010
    Melb Westsideeeee
    I know its a bit far fetched perhaps for you, but there is a small shop called West Side Carburator something something. They specialize in i think all carbies and should be able to help.
    Its on Write str just infront of Totenham train station.
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
    Feb 2007
    Scratch that, its not a webber. Its a motorcraft. I was told it was a webber.
    MK1 GLS 3door
    A4 B7 2.0T
    Jun 2007
    Eastern Suburbs Melbourne
    take it to a carb shop and see what they say.
    rebuild should be about 150-200 iirc. You could whack a seal kit in it for about 50 or 60 bucks, but only if you're methodical and good with fiddly stuff, and the carb is in reasonable condition to start with..
    i like volkswagens
    Aug 2009
    I had the two Zenith carbs on my other car rebuilt for $120. Only money I've had to spend on it in over 2 years.
    Aug 2006
    Melbourne VIC
    The Carby Shop
    5 Sherwood Crt, Wantirna, VIC 3152
    p: (03) 98013984
    He has rebuilt mine, my Dad's, Peter's and Josh's plus many more.
    Dec 2006
    Quote Originally Posted by Spyda View Post
    The Motorcraft marking means its built by Holley ( under license from weber ) so its very similar to the weber 32/36.
    Its probably a 'Holley G180' of the '5200 series' which is sometimes confused with the weber because of their visual similarities.
    As others have said you could take it to a carby shop or give it a good clean and put a kit through it yourself
    1978 Golf GLS
    1997 Golf GL
    Feb 2007
    Cheers guys.
    Ill take the Motorcraft carbie to a few places and see what they say.
    MK1 GLS 3door
    A4 B7 2.0T
