Results 1 to 6 of 6
Thread: Removing C.v Joint Help!!
    Aug 2008
    SYDNEY
    i recently had a little "mishap" with a medien strip and buckled a rim and tore the rubber boot on a outer cv. i got a new boot and i've been trying to remove the c.v with no luck, i know you got to spread the c clip but it just springs back into place.....and i cant hammer the cv of the shaft whilst holding the c clip. what are your methods of doing this job? any tips???
    its starting to really annoy me!
    2008 POLO GTI - SOLD
    2005 MkV Golf GTI - couldn't resist
    Apr 2006
    Hobart,Tas
    You are using circlip pliers right?? shouldnt have any problems at all if you are.
    Good luck. Spread the clip and very gently tap the joint, easy as.
    Andrew
    Aug 2008
    SYDNEY
    Quote Originally Posted by gtimk5 View Post
    Andrew
    yep c clip pliers. how much am i meant to spread it, how tight is the cv joint meant to be on the shaft??? thats a bit of a vague question i know....
    Jul 2006
    Andrew
    Now that you have a real answer, I feel I can post this:
    The solution is to sell me your Golf because its the hottest mk1 colour I have seen in a long time
    Any other photos?
    Apr 2006
    Hobart,Tas
    The joint is not tight on the shaft at all. Once you get the clip out of the groove the joint will easily pull off the shaft with your hands. Its just getting the clip out of the groove and away you go. One thing, dont lose your patience, just tinker, open the c clip as far as it will go and persevere.
    Aug 2008
    SYDNEY
    thanks for the advice, worked like a charm. advice + beer = result. but it started raining again so i dont think i'll be able to put it together again till tomorrow.
    cam0x- this is my daily till NOV after that it'll be for sale.....contact me in 8 months.
    cheers
    john
