Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: remove helper spring for moar low? hottuning
    Jun 2007
    Eastern Suburbs Melbourne
    the strut top you mean? Do you have the proper tool? cause it helps immensly!
    i like volkswagens
    Jan 2009
    south west sydney
    There's a proper tool for it?
    Apr 2009
    Newport, NSW.
    For the fronts, you can use an allen key and a spanner. For the rears you can use two spanners...or a pair of pliers for me
    There's another way to lower the rear but it requires a bit of fabrication. Years ago on my GLS I welded on 2 x 5mm thick metal plates on the bracket that holds the bottom of each rear shock (4 metal plates in total, each 70mm x 40mm x 5mm). I them drilled a couple of holes 20 mm apart and parallel to the hole that bolts the lower shock absorber. I now had 3 sets of holes that I could bolt the shocks to, each one 20mm lower than the other so I could lower the car 40mm just by bolting each rear shock in the lowest hole.
    If you have trouble visualising this then don't attempt to do it. It's not something you can slap together and the brackets have to be as strong as the original shockie mount. Using a l_l shaped piece turned on it's side would be better as it keeps the sides parallel and you have more surface area to weld with.
    Paul
    Jun 2007
    I think I know what you mean Paul. You can also use drop plates. This basically drops raises the point of where the stub axle mounts onto the beam, which lowered the car. guys in the US use them on caddy's alot
    i like volkswagens
