you wont get heeeaaaaappssss more. But you will get moar lows definately!![]()
Hey dudes. If i remove the helper spring (<---- termanology?) i should be able to drop the rear of the car a heap more huh?
i only want an extra 20mm or so but am maxed out on the lowest setting...
nah you'll get not much adn bugger all out of it (on the fronts atleast, I doubt it'd be radically different with the rears)
chances are you'll just be riding on bump stops which makes for a pretty crap ride.
alternative is to space out the rear wheels. Gives the impression you are lower, just cause there is less tyre-wheel arch gap, it's what i did on my old GLD.
other option is to raise the rear strut tops, obviously that involves welding and such, and clearancing of a few things under the rear end (due to the beam being on such a great angle)
hth
p.s. you coming to nationals?
i'm happy with how the front sits. i've got some 15mm spacers on the way thanks to GoLfMan for the rear... see how it looks then i spose.
yup going to nationals. the car wont be in that great shape.... i bought an s13 silvia so have gotten a bit side tracked. but i'll be there, got a couple of things planned to finish before then.![]()
Get smaller wheels and tyres, your will sit sump bashingly low but stil maintain a decent ride. Like Jrad said, if you take out the helpers you will be riding on bump stops and itll be craptastic.
MK1 GLS 3door
A4 B7 2.0T
I removed the helper springs from my coilovers as they hit the tyre..
Looking at it, you could lower it a fair bit with them off, but as Jarred said you'll just end up sitting on the bump stops, unless you cut em down I guess.
I reckon smaller wheels/tyres.... maybe like 13's with a lower profile tyre..
2012 Ford Focus - Panther Black
Previous - 1977 VW Golf GLS - 2E (beige beast)
Previous - 1976 VW Golf Ls (flipper blue)
The height differences wasn't phenominal. at least it was like 10mm of actual more low. If you're really craving the lows get some strut top spacers. 2" drop will actually give you a 2" drop. BUT there's alot of work involved when you start to do this. ask me at nats and i'll explain it in person. much easier when i cant point at things.
i'm happy with how low the front goes... for the back to match the front i think it needs to come down like 20mm.
farking crushed the end of my ring finger trying to get the bearing cap things off the front tonight... still no luck. too late for compressor. damn it
