Results 1 to 10 of 17
Thread: The rebuild starts
    The rebuild starts
    Finally!!! Time to start putting bits back on the Mk1 (for good this time).
    Apart from some embarrassing moments when I realise I gave away some crucial bits (the little Y shaped bits to connect the pedal to the bell-crank, and the other one that connects to the booster - sigh!)
    Anyway... some quick pics
    My rebuilt gear shift -
    Wheel, pedals, gearshift and handbrake
    Rack and other bits including the pedal box
    It's been a while...
    sydney
    wow looking amazing
    did you reweld a whole section of plate in the footwells??
    aand where did you source the master cylinders from??are you running .625 bore??or .7
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
    blackgti1.8 Guest
    Nothing like a pristine new shell comming together - are you sure
    you're not building a show car?
    Yeah, I know - we're pussies (or something)
    A couple of questions - is that a balance bar sticking out of the master cylinder bracket? Did you consider an internal peddle box setup to get rid of
    that brake linkage? (yeah, more work I know...)
    I desperately wanted to lose the bar and bell-cranks, but this guy in England was advertising a MK1 pedal-box which I bought sight unseen. So the good news was that it was designed specifically for a RHD mk1, the bad news was that it simply replaces the booster. Oh well
    It has a dash mounted adjuster for the balance-bar, the MCs are .625 and .7 respectively.
    The floor was plated with 6mm aluminum by the wizard that built the roll-cage and reinforced the shell big-time. This was my original post and the pics should answer the question better than words
    Thanks for the kind words (sorry about the previous 'pussy' jibe)
    Charles.
    Apr 2006
    Asaka-shi Saitama Japan (from Tassie)
    That is so neat! i hope you dont plan on driving it!!!!!!!!!
    Cheers, Benny
    www.axesent.com.au
    sydney
    i remebered something about alloy i just thought the painted finished product looked like steel and one piece
    i sourced a cabin side mounted pedal box from the uk and its a great bit of kit
    looking great charles
    Quote Originally Posted by dubstarmk2 View Post
    Details please?? (for next time)
    Mine cost about 300 quid with dash mounted adjuster and remote reservoirs.
    c
    Oct 2006
    I hope your gonna clean your feet, shoes off before you enter the car!
    Looking good as always
    sydney
    from my man mickey marrows on the edition 38 forum its a great fit, i think mine was around that price but without cylinders, it is part of the steering column and mounts directly to the firewall bulkhead. i had to source a blank steering column in the uk to sort out the build
    without the mods
    and with my custom pedals
