Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: rear sway bar??
    Camden, Sydney
    Bottom Front brace, Top Front, Back Top. In that order for usefullness.
    You only need the back for motorsport really.
    Golfwise Guest
    My point is that one shouldn't put a front ARB on without a rear one .The rear one is the most important one not the front one.Its not an old Holden .
    The factory put ARBs on their GTi etc in pairs not front alone and in some cases put rear ones on without the front.
    Thats why I suggested you take the front one off untill you get a rear one .
    Lower stress bar is a must as it should have been built into the original design but in 1975 on 5 inch wheels and 155/13 tyres the slip angle factor would have saved any extra stresses on the lower pivot points.
    syncro Guest
    Quote Originally Posted by Golfwise
    That's why they put them as standard on 16V Sciroccos. The front lowers are the only stress bars that really make a big difference. Adjustable ones are BS. Adjust the body to factory specs.
    Jan 2006
    Ballarat, Victoria
    Umm!!
    What's a lower stress bar?
    What is it supposed to do?
    syncro Guest
    Measure a few Golfs and you will find out.
    Jan 2006
    Ballarat, Victoria
    Is the lower stress bar the same thing as a front lower strut brace?
    syncro Guest
    Quote Originally Posted by Campaign
    Yes
Similar Threads
  1. Removing rear window mk2 gti
    By ausgolfer in forum Bodywork/Trim & Detailing
    Last Post: 19-01-2007, 10:13 AM
  2. How does the rear sway bay fit up?
    By Peter Jones in forum Mk1 Golf
    Last Post: 20-11-2006, 09:16 AM
  3. Rear Sway bar
    By Green Mk3 in forum Mk3 Golf & Vento
    Last Post: 18-09-2006, 11:29 AM
