Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Ratty retro racer project
    Looking good but you seriously need some lows.
    Mar 2012
    central coast NSW
    Yeah low will happen after I get rego although it will probably be by the form of an angle grinder initially or just low springs I think coil overs are out of the budget build.
    Nothing wrong with the angle grinder approach, that's how all my earlier MK1's were lowered. Add a thick rear sway bar from any donor car that fits and a lower front strut brace and you've got a seriously good handling little car that can hassle modern sports cars through corners. You don't need coilovers when the cheap approach gives the same results for less than $100.
    Paul
    Jan 2007
    Amazing how new wheels can change the look of a car!
    I'd be careful with cutting springs unless you have done it before.
    I'd recommend at least doing it to a spare set.
    I'm sure you can get some cheap lowering springs- check eBay and gum tree. My mk2 ride improved so much with new mounts and lowering springs. Feels like a new car.
    07 GTI
    APR stage II
    Mar 2012
    central coast NSW
    Got rego today. So I can get to lowering now. Sports steering wheel is much better to drive with.
