Results 1 to 5 of 5
Thread: Radio Removal
    Beige76 Guest
    Radio Removal
    How do i get the radio out without breaking the plastic bit around it?
    Allens Rivulet, Tasmania
    if its the standard radio (probably sony) all you need to do is, take off both the volume and tuner knobs. beneath all the parts of the knobs you will find to small little nuts, all you need to do is remove this and the plastic face will slide off, and the security "peices" will to, freeing up the head unit all you need to do now is pull, and remove the wiring and aerial. good luck
    Anonymous Guest
    Quote Originally Posted by el_foolio
    Standard radio? The first Australian Golfs with a radio were in 1990 (Pioneer).
    true true, nice call
    Camden, Sydney
    If its a more modern radio and you have released the side with keys, or a bit of wire, reach up behind the radio and see if someone has attached it to the bulkhead with a bit of mechano. I`ve seen a few like that. Makes it fun to pull radio out.
Similar Threads
  1. Step by step bumper removal (56K Warning!)
    By Golfer in forum Mk3 Golf & Vento
    Last Post: 15-08-2008, 05:41 PM
  2. Downpipe spring clamps removal
    By aussieg60 in forum Mk2 Golf & Jetta
    Last Post: 31-07-2006, 05:44 PM
  3. MK3 Golf Lower control arm removal
    By George in forum Mk3 Golf & Vento
    Last Post: 04-07-2006, 12:27 AM
