if its the standard radio (probably sony) all you need to do is, take off both the volume and tuner knobs. beneath all the parts of the knobs you will find to small little nuts, all you need to do is remove this and the plastic face will slide off, and the security "peices" will to, freeing up the head unit all you need to do now is pull, and remove the wiring and aerial. good luck![]()
