Why not fit an aftermarket one?
finally the fan is gone..
mechanic says can't rebuild the fan..
and need to replace with new one..
anyone know the part number or where i can find it?
1976 golf mk1 1600cc carby model..
please help me..
1976 VW Golf LS 4Door 1600cc
it will obviously mean making/modifying brackets as well as the electrical connection, but you can buy them from auto part shops(davies craig is one brand). you could use a second hand one from any other type of car, they all do the same thing. have you tried any of the wreckers for a proper vw one?
For the best efficiency you're going to need one with a shroud around it so it sucks air only through the radiator and not from around the edges of the fan. You live in a slightly warmer climate than me so keeping your car cool is really important.
If you get a Davies Craig fan or similar get the biggest one that will fit or get 2 smaller ones. Make sure they come with a shroud or mount them so they almost touch the radiator - about 5mm is OK.
Alternatively find one the same size of your current one and make some brackets so it fits the same as your old fan.
Paul
